Looking for the ability to define ncm node groups during the network discovery. Again to assist with schedule/automated network discovery.
aaswi,
Are you using a standalone NCM system or is it installed with NPM? If so, you have better depth in grouping those Nodes with Custom Properties than with NCM legacy Node Groups.
Derik Pfeffer
ncm standalone
aawi,
Do you have the ability to add Custom Properties in your standalone instance? If so, I would use them over Node Groups for the flexible. These then can be used for executing scripts or scheduling jobs., etc..
