Allow for DPA to seamlessly install and monitor an instance of Amazon RDS.
Hi sqlrockstar,
Do any Solarwinds products support RDS? I haven't been able to find any info on it. I spoke with a SQL admin that I work with and he mentioned RDS doesn't allow the SA account to be exposed so it didn't work when he tried. Any workarounds that you know of?
Danny
Have you seen these KB posts already?
Monitoring SQL Server Instance in Amazon RDS - Confio Article 1684
Monitoring an Oracle Database in an Amazon RDS Environment - Confio Article 1679
Script to Create the X$ Views for Monitoring Oracle Amazon RDS - Confio Article 1680
Hi Brian,
Yes I read the first one but I couldn't find anything specific to NPM or NCM. The setup wizard fails on both products.
At present we do not test against RDS for use as NPM/NCM back-end, so unfortunately cannot comment. We will look to do so in the future however.
You can find information about this feature that was implemented in DPA 9.1 here Database Performance Analyzer 9.1 Release Candidate is available now!!!!
