at the moment we have to add a Search Widget to all views.
It would be great if there is a general search for example at the top right, which is visible at every view.
How many clicks does it take to get to a node? (There might be joke in there somewhere.)
This is something I wish was more efficient as well. I think this is a great idea!
Wait.... There is one... The funny part is I only noticed it because I saw one of my users doing it. I don't know what version it appeared in, but it was not there when I first installed orion.
I must have noticed that icon at some point since I had some recent searches show up there. Still seems like there are too many clicks after the search to get to the node. Maybe the enhancement should be that when you start typing a node name in that search bar then a list of matching nodes start to show up as you type, and then you can click on the a link to get to the node.
jfaldmo wrote:I must have noticed that icon at some point since I had some recent searches show up there. Still seems like there are too many clicks after the search to get to the node. Maybe the enhancement should be that when you start typing a node name in that search bar then a list of matching nodes start to show up as you type, and then you can click on the a link to get to the node.
jfaldmo wrote:
This was delivered in 12.2 https://support.solarwinds.com/Success_Center/Network_Performance_Monitor_(NPM)/NPM_Documentation/Previous_Versions/NPM_…
