Currently there is no Critical option available under the drop down list to configure the alert for threshold above 90% or 95%
Volume status is equal to = CRITICAL option should be added.
PFA.,
rahuls266,
I believe there is an option for Critical Threshold has been reached for Volumes. This would give you a True/False based on whatever has been set for Volume Critical Threshold Values. There is also one for Warning, as these are separate from the Status options. I am away from my systems otherwise I would have included a screen shot as well.
Best Regards,
Derik Pfeffer
LinkIN: Loop1 Systems
Facebook: Loop1 Systems
Twitter: @Loop1Systems
Hi Dreik,
Thank you for your update!
Could you please help me with the steps as well..
Here is a great article to cover this topic.
https://thwack.solarwinds.com/docs/DOC-194030
Loop1 Systems - SolarWinds Training and Professional Services
