This is a controversial question for a Friday.
Right!!! ??
At previous companies I have, but my current employer does not have one.
It's a hard question. No, that's not right. it's a too rigid set of answers. When you run most of the Orion modules and options & have already built a load of automation, I see it as an evolution of Orion, but not for today and there's no option for that.
Is this week's Friday vote question not going to register as answered like last week's did? Oy. Maybe it's from answering it on my phone while on vacation.
How do I get this to count the day as being completed? None of the Fridays appears as completed for me.
As a small rural utility and subsidiary SP, we depend upon our SW integration to monitor our company infrastructure and communication to our upstream SP. Our upstream SP and partner uses their SW integration and provides tools and modern dashboards to monitor our traffic and external plant structure. In a cooperative effort we are leveraging TWO company assets to implement our observability solution. This cooperation will grow as our plant expands with other SP connections.
Alright!
