I am the proud owner of two Welsh Corgis, who are the cutest little sausages you've ever seen, so we all know where my vote is going.
LETS GO! COWBOY BEEBOP!!!! EIN ALL DAY! \m/
Ein all the way
EIN FTW!!!! And forever love for my 3 corgi's I had growing up!
Ein!
One, while siting in a hospital waiting room for a long time, I was subjected to two straight hours of Spongebob Squarepants. I am mentally scarred for life.
Ein wins all over the galaxies!
\m/
