Community
Command Central
MVP Program
Monthly Mission
Blogs
Groups
Events
Media Vault
SolarWinds Academy
Products
Observability
Application Management
IT Security
IT Service Management
System Management
Database Management
Goal Oriented AI
Content Exchange
SolarWinds Platform
Server & Application Monitor
Database Performance Analyzer
Server Configuration Monitor
Network Performance Monitor
Network Configuration Manager
SQL Sentry
Web Help Desk
Free Tools & Trials
Store
Home
Products
Problem sending mail with Syslog and Traps
Fenclo
I have a problem when I try to send an e-mail when a Trap or a Syslog message is catch. I tested to send me all traps from my server and nothing. My services are running and I can see my current traps and Syslog messages.
But if I setup rules in NetPerfMon Alerts, it's OK. I receive all my messages.
Anyone have a solution ?
Find more posts tagged with
Accepted answers
All comments
rknight
I have a similar problem with Traps. When I define an action of send an email message in the Trap Viewer application no action is taken. There is no evidence from my smtp server logs that a connection was even attempted by the trap service.
Actions to change the colour of the message and log to the Event Log on the local Windows machine work, however the SMTP portion of the trap service seems to be broken.
Cheers
Ric Knight
rknight
The forward trap action works correctly as well... just smtp woes
Cheers
Ric Knight
Josh_Stephens
You are correct - the current beta release of the Orion Trap Receiver has an issue and will not send out alerts via e-mail. We should have a fix for this available eithin a few weeks.
Please let us know if you see any other issues and thank you for your support.
Sincerely,
Josh Stephens
SolarWinds.Net
rknight
Thanks Josh, looking forward to a new release.
Cheers
Ric Knight
denewto
Ric & all:
Until the new Orion trap release is posted; a work-around for getting E-mails to work from the TrapViewer rules is as follows: In the rule you are creating with an E-mail action, put an E-mail address in the TO, the .CC and the .BCC fields and your E-mail should send correctly.
David Newton
Solarwinds.Net
rknight
Thanks for this work around... seems to do the trick
Cheers
Ric Knight
Quick Links
All Categories
Recent Posts
Activity
Unanswered
Groups
Help
Best Of
