specific color for 10G interfaces
teh unknown speed links gray is hardly seen
Ovad.
Make sure UNKNOWN Speed link is ticked. Once performed the color changes to dark grey. Hope this helps.
I got the license and I found some issues with export links to network Atlas – please let me know if you want me to open a support ticket .
1. Links discovered fine between 2 6509 are exported to Atlas without the Link information
2. Additional incorrect links that does exist are are added to the NTM map (and exported to Atlas), there are only 4 links there, all unknown are incorrect
This message and the information contained herein is proprietary and confidential and subject to the Amdocs policy statement,
you may review at www.amdocs.com/email_disclaimer.asp
Hi Ovad,
1. Links discovered fine between 2 6509 are exported to Atlas without the Link information.
- This is true, Only Nodes information and line connectivity between the nodes are exported to Network Atlas. May I ask, what's the use case, for having Link information into Network Atlas ? what benefit it brings ?
2. Additional incorrect links that does exist are added to the NTM map (and exported to Atlas), there are only 4 links there, all unknown are incorrect.
- Am not about to see the picture. Can you open a ticket with support (Customer Portal) ? We will need diagnostics and export of the maps.
Our core environments consist of nexus7 and 5 and 6500,
The N5 does not respond to QMIB or Bridge MIB, thus network atlas unable to MAP it ,
So in order to get accurate MAP I must use NTM, however I want the map to be alive so I must export it to Atlas.
Not having this information makes NTM not very useful for me – is it something that can be added?
I will open a ticket for the second issue
Ovad
