quote:Originally posted by RyanJettquote:Originally posted by cherrypickerNice to have...Orion should have to ability to monitor Windows event logs? It would be nice if it can be incorporated into the alerting engine as well.Any thoughts?CPThere is a free add-on utility that can be installed on Windows Servers that forwards the Event Logs via Syslog Messages. This can be downloaded in the Customer Area of the SolarWinds website. Once logged in, go to Additional Components for Orion, and download the Windows Event Log Forwarder.Ryan JettSolarWinds.Net918-307-8100
quote:Originally posted by cherrypickerquote:Originally posted by RyanJettquote:Originally posted by cherrypickerNice to have...Orion should have to ability to monitor Windows event logs? It would be nice if it can be incorporated into the alerting engine as well.Any thoughts?CPThere is a free add-on utility that can be installed on Windows Servers that forwards the Event Logs via Syslog Messages. This can be downloaded in the Customer Area of the SolarWinds website. Once logged in, go to Additional Components for Orion, and download the Windows Event Log Forwarder.Ryan JettSolarWinds.Net918-307-8100Is there a similar utility for Unix, Linux and Solaris boxes?
quote:Originally posted by casmith32What about dependencies ? I would be great to have the ability to create device groups, then assign dependencies to the group as a whole - i.e. all switches behind a router at a site are dependant on the router. Then have the option to have alerting set to not alert on the nodes dependant on another node... i.e. if router x goes down, automatically do not alert on all the nodes dependant on that node.will this ever happen ? it's a real pain to have to setup an alert and it's supression for every site I have, as well as dependencies within that site for larger locations. I'd like to see this simplified. that way if I add a switch or any other node to a group - I know it's automatically going to be covered in an alert that's already been created, vs having to go update the alert each time. I imagine this grouping capability could also be applied to numerous other functionality within orion - view limitations, reporting, etc...
quote:Originally posted by Network_GuruHey Chapter 15+14,I think you will find a solution in this post:www2.solarwinds.net/.../topic.asp-=Cheers=- NG
