quote:Originally posted by CCrewStill no hooks into the Application Management pack?-Roger
quote:Originally posted by Don331Still need some way to set up a global alert supression easily. A good example is a branch office that has a router, a switch, and a server.Having to set up a rule for every device in a branch gets old real fast.It would be cool to have a table to group the node ID's of nodes into logical groups, and then set up at least 2 levels of supression .
quote:Originally posted by bleearg132 suggestions:1. I think it would also help to have a "Are you sure?" to "PEBKAC"-proof the deletion of alerts. I've deleted an important alert at least once in the alert engine that comes with the Orion distributation. I'll say it was because of an overanxious trigger finger :-/2. The ability to acknowledge an alert via the Orion website. Maybe this is already integrated, but I'm too blind to find it?-evt
quote:Originally posted by praghubarOur weekend computer staff frequently re-boot servers, which sends Email and phone call alerts to the On-call person. How can I suppress these type of alerts with the New alert engine?thanksPeter
quote:Originally posted by Don YonceKeep in mind, this is a "pre-release", not the final release.On the macros .... we will probably be adding a Macro Builder feature to the actions. The supported Macros in the new engine are far, far more advanced than the previous version. The new set of Macros can be as simple as the current set, or as complex as refering to related devices or interfaces, or even run SQL statements. So... a Macro Builder will be needed.As for Test Alerts. It is not available in the pre-release. They are still unsure what the best method of implementing that feature is. Since, the new Alert Engine is service based, generating a genuine Test Alert is more difficult. But, I'm sure they will figure something out.
quote:Originally posted by cherrypickerThe escalation is pretty limited - would like to see features such as groups, scheduling (for on call person). Would like the ability to acknowledge the alert via email in addition to the Alert Manager.
quote:Originally posted by cherrypickerNice to have...Orion should have to ability to monitor Windows event logs? It would be nice if it can be incorporated into the alerting engine as well.Any thoughts?CP
quote:Originally posted by RyanJettquote:Originally posted by cherrypickerNice to have...Orion should have to ability to monitor Windows event logs? It would be nice if it can be incorporated into the alerting engine as well.Any thoughts?CPThere is a free add-on utility that can be installed on Windows Servers that forwards the Event Logs via Syslog Messages. This can be downloaded in the Customer Area of the SolarWinds website. Once logged in, go to Additional Components for Orion, and download the Windows Event Log Forwarder.Ryan JettSolarWinds.Net918-307-8100
quote:Originally posted by cherrypickerquote:Originally posted by RyanJettquote:Originally posted by cherrypickerNice to have...Orion should have to ability to monitor Windows event logs? It would be nice if it can be incorporated into the alerting engine as well.Any thoughts?CPThere is a free add-on utility that can be installed on Windows Servers that forwards the Event Logs via Syslog Messages. This can be downloaded in the Customer Area of the SolarWinds website. Once logged in, go to Additional Components for Orion, and download the Windows Event Log Forwarder.Ryan JettSolarWinds.Net918-307-8100Is there a similar utility for Unix, Linux and Solaris boxes?
quote:Originally posted by casmith32What about dependencies ? I would be great to have the ability to create device groups, then assign dependencies to the group as a whole - i.e. all switches behind a router at a site are dependant on the router. Then have the option to have alerting set to not alert on the nodes dependant on another node... i.e. if router x goes down, automatically do not alert on all the nodes dependant on that node.will this ever happen ? it's a real pain to have to setup an alert and it's supression for every site I have, as well as dependencies within that site for larger locations. I'd like to see this simplified. that way if I add a switch or any other node to a group - I know it's automatically going to be covered in an alert that's already been created, vs having to go update the alert each time. I imagine this grouping capability could also be applied to numerous other functionality within orion - view limitations, reporting, etc...
quote:Originally posted by Network_GuruHey Chapter 15+14,I think you will find a solution in this post:www2.solarwinds.net/.../topic.asp-=Cheers=- NG
