SAM 2020.2.6 updates for API poller templates include:
The following API poller templates were updated to support changes in remote APIs:
Important: Recreate existing API pollers based on these templates to use the latest version. Otherwise, polling stops.
To learn more about API poller templates, see the SAM API Poller Template Guide.
Cool, will have to give it a blast.
Hi, updated to this version yesterday and all my solarwinds-callback API monitors are broken now, is this intentional?
Some of the SAM API Microsoft 365 templates not working, since the https://manage.office.com/api is no longer supported by Microsoft. Created Request to recreate these using Graph API. (+) Recreate SAM API Microsoft 365 templates to use Graph API - Feature Requests - Server & Application Monitor (SAM) - THWACK (solarwinds.com)
We are running this version and can't find any of these API Templates. How do we import them into API pollers for use? I've searched all over Thwack and through all the install folders and can't find any of them.
