2.) Visual firewall connection mapping (3.) Dynamically generated traffic maps
2) Dynamically generated traffic maps
3) Visual firewall connection mapping
Traffic information in NetPath
1 & 5
2. Dynamically generated traffic maps
3. Visual firewall connection mapping
Visual FW connection mapping and SD-WAN edge maps.
AP Maps, Load Balancer environment mapping
Load balancers are one of the most important parts of the services in many companies so we need more integration there to see what is happening. Visual connection mapping is important too. I like to work through with network teams to build detailed diagrams of their networks port by port so more detailed auto created dashboards for critical ports would be great.
Traffic information in NetPath and Wireless controller/AP maps
Traffic information in NetPath and Wireless Controller/AP Maps
Traffic information in NetPath and Dynamically generated traffic maps
Traffic info in NetPath, Traffic Maps, Firewall mapping.
Dynamically generated traffic maps\Traffic information in NetPath
NetFlow and network mapping created from the network device configuration (created by an external provider)
I'm a DBA so this question doesn't really apply, but you didn't give an option for that.
Expanded load balancer environment monitoring
Firewall & Network Traffic
Dynamically generated traffic maps and Wireless controller/AP maps.
SD-WAN VPNs in NetPath / firewall traffic
SD-WAN VPNs in NetPath Firewall traffic
Traffic information is the most important
My green check mark never stuck for some reason?
Wifi
I've commented already.
2nd - Wireless Heat Maps
This one still is not showing completed.
Wireless controller/AP maps and Visual firewall connection mapping
