IF YOU TAKE THIS POLL BEFORE FRIDAY DECEMBER 8TH OR FROM THE COMMAND CENTER VS. THE MISSION, YOU WILL NOT RECEIVE MISSION CREDIT
I like to lay on a couch while I'm fed grapes. I haven't found an IT baking habit that can do that for me yet.
I think the best meal is one that is made for me. :-) However, I do love to grill the meats.
I don't like anything
Okay, Hedonism Bot lol
Okay, this one wins me over. Although, this one has implications of HAL. So its a upvote for me and a new source of nightmares. Impressive!
Although I like to have my menu outside, sometimes it's better to cook it at home
I always prefer Hybrid cloud environment.
\m/
