In a future version, it would be helpful to be able to re-order charts on a page or metrics within a chart. Currently the only way is to remove the metric or chart and re-add/re-create them in the desired order.
We use Perfstack to track multiple ISP interfaces. We always add the metrics in the same order so we can quickly scan over the page looking at transmit and receive on the multiple interfaces. When Perfstack decides to reorder the metrics on its own, we then have to look at each individual entity and verify which color is what metric for each graph. This is a huge oversight from the development team for this tool.
PerfStack reordering metrics automatically in saved PerfStacks was a bug in its first release. This was addressed and resolved in the NPM 12.2 release.
Thank you for this information. I have an open ticket for this and no one has mentioned that it was fixed in 12.2. I was told to put in a feature request.
Your support engineer was likely unaware of the defect, but I assure you that it is resolved in NPM 12.2.
Just to clarify - the color reordering was not what I was referring to with this... this is an open request to be able to move content around on the perfstack page without having to delete and re-create it which is extremely time consuming. Thanks!
bump
