IF YOU TAKE THIS POLL BEFORE FRIDAY MAY 24TH OR FROM THE COMMAND CENTER VS. THE MISSION, YOU WILL NOT RECEIVE MISSION CREDIT
I would like to leave this as my legacy when I (move on to a new horizon of opportunities)! It's too early to retire!!! It may, however, be time for a change in the future! I was excited to get exposed to this offering at my last SWUG in Minnesota!
\m/
