Don't click on the π!
Better watch out for the Praetorians!
On [mention:144f2fe4665a451dbccc5390df6ef96f:ca0e7c8086864d2fa5a863b9e212e922] Episode #12. Harold and Alex Mann - The Net (1995) we talked to two technical consultants on The Net. It was interesting to hear their take on realism vs. art. Plus, they had some cool stories from working on the set.
I wrote a blog in 2017 on Thwack about why movies like The Net drove me nuts. Good read, but I'm biased: "IT" Portrayed in Hollywood
