THWACKnation - Are any of you monitoring Windows workloads in AWS? Or even just the OS? Please comment below, we have a team that would like to speak with you!
nope sorry.
Yes, we use the cloud monitoring and for the few servers that are able to we have the Orion agent running on them.
\m/
