\m/
Very small impact. On my deployment with 12 Orion products installed, there was a 2% uptick on CPU and I didn't see any change in memory.
Does running the diags have any significant performance impact on the server?
Active Diagnostics was bundled into Orion Platform 2018.2 (Troubleshoot Orion Deployment issues with Active Diagnostics ). It should be available on your system.
What version of Windows and SQL are you running? I'm sure we can help get you an upgrade path. In fact, there was a THWACK Tuesday Tips (Triple-T) video about upgrade planning: How to Check the Compatibility of Your Orion Products Before Upgrading
For what release is this ? My Orion Deployment does not show up on my screen.
(Orion Platform 2018.2 HF5, IPAM 4.7.0, NCM 7.8, CloudMonitoring 2.0.1, NPM 12.3, NTA 4.2.3, UDT 3.3.1, NetPath 1.1.3)
I have not been able to upgrade due to SQL and the servers not yet upgraded. That is another bone to pick about updates vs. upgrades.
Thanks for the help.
Mark
