Community
Command Central
MVP Program
Monthly Mission
Blogs
Groups
Events
Media Vault
SolarWinds Academy
Products
Goal Oriented AI
Observability
Application Management
IT Security
IT Service Management
System Management
Database Management
Content Exchange
SolarWinds Platform
Server & Application Monitor
Database Performance Analyzer
Server Configuration Monitor
Network Performance Monitor
Network Configuration Manager
SQL Sentry
Web Help Desk
Free Tools & Trials
Store
Home
Products
Errors and Discards
pn1995
Hello We are running the Orian product and have it monitoring a number of our Cisco 2600 routers.
On one of the routers we are getting a lot of "Transmit Discards" and on another one we are getting lots of "Receive Errors"
Does anyone know if this means we have a problem with the router? or what is it actually indicating.
Find more posts tagged with
Accepted answers
All comments
Network_Guru
pn1995,
Have a look at this post:
www2.solarwinds.net/.../topic.asp
-=Cheers=-
NG
smcdonald
Most common causes of this type of thing I've seen is duplex mismatch or bad cables. Check that your port speeds match on both sides - eg 10/half or 100/full (assuming this is ethernet) - don't use Auto as this can be problematic on some devices - much better to fix the speed when it comes to router and switch connections.
Failing that try replacing the cables
Sean
Mithrilhall
I was just getting a ton of receive and crc errors on one of my routers the other day.
Turned out to be a bad smartjack.
Quick Links
All Categories
Recent Posts
Activity
Unanswered
Groups
Help
Best Of
