How much do you really know about the SolarWinds© Orion© Platform? Regardless of your level of expertise, even the most seasoned user will learn a thing or two in this episode. We'll go through dashboards, customizations, features, functions, you name it. Learn from Orion Platform experts, ask them questions, and share your own pro tips during live chat and Q&A.
https://play.vidyard.com/q4jw5T1xai9jNZhmyxqwzt
Additional Resources
5 Easy Methods for Improving Your Dashboards
THWACK Tuesday Tip: How to Quickly Identify Suspicious Network Behavior With Intuitive Dashboards
My Dashboards in the Orion Platform
How to Add a PerfStack Widget to Your Orion Dashboard - Video
https://support.solarwinds.com/SuccessCenter/s/article/How-to-Add-a-PerfStack-Widget-to-Your-Orion-Dashboard-Video
https://support.solarwinds.com/SuccessCenter/s/article/SolarWinds-Performance-Analysis-PerfStack
https://thwack.solarwinds.com/t5/Lab-Documents/SolarWinds-Admin-Dasboard-zip/ta-p/511017
https://thwack.solarwinds.com/t5/NPM-Documents/ViewImporter-ps1/ta-p/512357
Video not found
Hi
Is it posible to get the video ? I cant see it .
Matt & Kevin,
This was a very good SolarWinds Lab.
Look forward to your next SolarWinds Lab Episode together.
