Be in five places at once means you have to do 5 times as much work...... ;-)
Time Machine with the ability to go back or forward to any point in time.
I HAVE THE POWER!!!
The Data Alchemist
This power goes beyond simply "hearing" the data. It's about transforming raw, chaotic data streams into clear, actionable insights, almost like turning lead into gold.
Clone mode. More "me"s would make one heck of an IT department. Do I get the salary of 5 people too?
Both Quantum Clone Mode with Control-Z (undo the last change) and the ability to read minds....
I mean, time freeze obviously....but not for any reason other than being able to mess with people
Any answer with *quantum* and/or *AI* has to be the correct/best - right? Although I am fond of alternate realities...
This is too much power for any one admin.
