IF YOU TAKE THIS POLL BEFORE FRIDAY FEBRUARY 16TH OR FROM THE COMMAND CENTER VS. THE MISSION, YOU WILL NOT RECEIVE MISSION CREDIT
\m/
very poorly probably still qualifies as a spreadsheet :P
I selected a manual entry system. After that we have QR codes that get printed and attached to assets that we can scan with an App to get access to the device info in the system.
We are using SWSD, and its discovery options
My first answer to the survey was "very poorly", but that wasn't an option.
On paper, my organization falls under answer "C". In actuality, it seems more like a combo of A, B, & C.
The only thing consistent at work is the consistency of inconsistency.
Obviously for isolated networks some is manual but for connected assets its all automated with agents and scanning for what's on the network and when.
