We would love to be able to monitor Dell EMC PowerStore with SRM. Any plans to add support for this?
Yes, this would be very usefull!
Hello I have a client who would like to know if Powerstore is supported - as far as I can see it isnt but can someone confirm? It says Powervault is supported and they have enough similarities so would it work for Powerstore ?
It's not yet directly supported. I don't think the PowerVault monitor will work because PowerStore uses an API for monitoring, but crazier things have happened. I'll try to test this next week.
I just checked SRM's potential support for monitoring PowerVault. The first step, as you can see in the screenshot below, is to point it to the SMI-S provider that is configured for the storage array. The PowerStore platform has dropped SMI-S in favor of using specific APIs for monitoring and management. Unfortunately, that effectively rules PowerStore out from this approach.
we need both powerstore and powerscale devices
Isn't powerscale the new version of the isilon?
Looks like this has not been on the "What we're working on" list of SRM
Tough positioning SRM ..
Fear SRM might sunset (not just the fact that too many storage devices are not supported nut also the fact that the new HCO platform does not include SRM in the story)
@abdhijasharma@dianac@sagar.b@Shravya29@tayyab@jayaraj.kaliamurthi
Upvoted. A customer is using PowerStore
We just replaced all of our VNX arrays with PowerStores. Now SRM is just a boat anchor for us...
We are also in need of both Powerstore and Powerscale for our enterprise DC monitoring
Upvoted. We also replaced VNX with PowerStore and our SRM just became a boat anchor.
Need PowerStore or we don't need SRM
I’m nearly there, too. We have one array that SRM can monitor.
We're in the same situation with our most of our critical workloads being on PowerStore now. We'll be dropping SRM and evaluating other tools across the board if this isn't resolved
I've just uploaded an API poller template for this for SAM thwack.solarwinds.com/.../3840
SolarWinds needs to keep adding support for newer storage devices.
SRM is in HCO
Licensing is separate SRM & WPM compatibility with 2022.3
By when Dell Powerstore 3000T will be supported?
We are waiting for more than 2 years now
We need this feature
Coming in about 2 releases time so watch this space
