An automated way to export the diagrams to Visio format, and the ability to specify the location they are saved at.
">shadowsbear Can you give me use-case why this feature would benefit you ?
Currently the Maps are saved in a format that only Network Topology Mapper can Read. Since we use Visio to create network Maps for future reference. Currently you have to go into Network Topology Mapper Select the diagram, and then export it to Visio. Since we have over 103 sites, we have to go through every single one, and export them to Visio, then save them in our diagram folder. It would be easer if there was an automated way to do this, which will save time where I do not have to have someone take time going through every diagram.
OK fair enough, and if we do bring it one day into the product, where would you want to this option available in the product ?
It would be nice to see it under: That way you have the option during the the configuration of the map to export it out.
Implemented in NTM 2.4.4: https://thwack.solarwinds.com/discussion/151719/announcing-network-topology-mapper-2-4-4-is-now-generally-available
