nice
this question isn't registering as answered for me on the main mission page either.
Visual firewall connection mapping and Dynamically generated traffic maps
1. traffic and firewall connection mapping
SD-WAN VPNs in NetPath / firewall traffic
Wireless controller/AP maps and Visual firewall connection mapping
This one still is not showing completed.
2nd - Wireless Heat Maps
I've commented already.
Wifi
My green check mark never stuck for some reason?
Traffic information is the most important
SD-WAN VPNs in NetPath Firewall traffic
Dynamically generated traffic maps and Wireless controller/AP maps.
Firewall & Network Traffic
Expanded load balancer environment monitoring
I'm a DBA so this question doesn't really apply, but you didn't give an option for that.
NetFlow and network mapping created from the network device configuration (created by an external provider)
Dynamically generated traffic maps\Traffic information in NetPath
Traffic info in NetPath, Traffic Maps, Firewall mapping.
Traffic information in NetPath and Dynamically generated traffic maps
Traffic information in NetPath and Wireless Controller/AP Maps
Traffic information in NetPath and Wireless controller/AP maps
Load balancers are one of the most important parts of the services in many companies so we need more integration there to see what is happening. Visual connection mapping is important too. I like to work through with network teams to build detailed diagrams of their networks port by port so more detailed auto created dashboards for critical ports would be great.
AP Maps, Load Balancer environment mapping
Visual FW connection mapping and SD-WAN edge maps.
2. Dynamically generated traffic maps
3. Visual firewall connection mapping
1 & 5
3) Visual firewall connection mapping
2) Dynamically generated traffic maps
2.) Visual firewall connection mapping (3.) Dynamically generated traffic maps
Traffic information in NetPath, Visual firewall connection mapping
Visual firewall connection mapping and Visual NSX maps
Visual NSX maps would be cool. I like the idea of visual firewall connection mapping also.
firewall connection mapping, dynamically generated traffic maps
Traffic information in NetPath, Dynamically generated traffic maps, Visual firewall connection mapping
firewall connection mapping, traffic in netpath
sd-wan vpns & dynamic connection maps
SD-WAN VPNs in NetPath / Dynamically generated traffic maps
Wireless controller/AP maps & Dynamically generated traffic maps
good
Netpath with traffic informatoin definitely, then dynamically generated traffic maps.
Traffic information
Firewall traffic
SD-WAN controller/edge maps and Wireless controller/AP maps
Netpath
We have to leave a comment I think?
AP maps and NetPath
Visual firewall connection mappingTraffic conversation deduplication
#2 - Visual firewall connection mapping #3 - Traffic information in NetPath
Routing neighbors deletion history
Visual firewall connection mapping/Dynamically generated traffic maps
traffic mapping/firewall
Traffic information in NetPath/ Expanded load balancer environment monitoring
I don't seem to be getting a green check mark for this even though I've completed it?
I'm adding a fourth! Visual firewall connection mapping
2 - Wireless maps
3 - Dynamic traffic maps
Will another comment get me credit for the monthly mission?
interesting
traffic maps would be terrific, netpath is a huge bonus then the SDWan edge (single pane of glass)
Traffic information in NetPath / Dynamically generated traffic map/Visual firewall connection mapping
Wireless controller/AP maps and Dynamically generated traffic maps.
and firewall traffic sd-wan vpns
Dynamically generated traffic maps and Traffic information in NetPath
2. Firewall mapping 3. Wireless controller/AP maps
2) dynamically generated traffic maps, 3) traffic infomration in netpath
Wireless controller/AP Maps, Visual NSX Maps, SD-WAN controller/edge Maps
visual firewall connection mappingexpanded load balancer environment monitoring
Simple things like interface status and bandwidth. Routing info.
Simple things such as interface status and bandwidth are the most important to me.
Simple things like Interface bandwidth and status. NetPath services is good too. I'd love it if you could have probes down to seconds instead of minutes.
NetPath is invaluable, dynamic traffic maps would be awesome - especially if they are live.
Dynamically generated traffic maps & Expanded load balancer environment monitoring
Traffic conversation de-duplication, dynamically generated traffic maps
visual firewall mapping would be nice
Visual firewall connection mapping and Wireless controller/AP maps
Dynamically generated traffic maps/Visual firewall connection mapping
Visual firewall connection mapping / Wireless controller/AP maps
Visual firewall connection mapping, Traffic information in NetPath
Firewall traffic/mapping and traffic data across the network
xxxx
