Too many secrets!
4sure! Setec Astronomy for the win!
It's Sneakers for me. Die Hard is my fav Christmas Movie, but after Die Hard 2, it all seemed a little ... forced.
Both of these movies covered on [mention:144f2fe4665a451dbccc5390df6ef96f:ca0e7c8086864d2fa5a863b9e212e922:label=Movies%20and%20Mainframes]. We definitely had a clear winner for this match-up.
Yes, but need I remind you...
Ben Kingsley could read the phone book for 4 hours and I'd vote for it for Best Movie of all time
The starpower cast alone puts Sneakers over the top: Redford, Potier, Strathairn, Akroyd, River Phoenix... plus a few other surprises.
If you haven't seen this movie add it to your list.
If you have not seen Sneakers, it is a treat. It shows red-teaming before red-teaming was a thing.
