Dear All,
This new market device which was used for backup was under monitoring.
Did you have a question, or did you just want to show off your snazzy new node?
Not much info here to work with...
I assume it was idle at the time and not doing anything.
Actifio is new product for backup solution. This is not idle state, we get more information about this device.
Again Actifio team working on hard ware and network interface information MIB.
We use Actifio as well. If i remember correctly, they do not support SNMP get yet.
I still don't have a context for the opening of this discussion. Is there a question you have about this product, or about integrating its monitoring into Orion?
