I already have npm 9.1 sp1. Just downloaded the new sp2, do I just shut down npm process then start the patch?
Is there anything special I should know before installing?
Thank You
Just run the install file.It will look after everything else for you - very painless.Kudos to SWs for this...
Yes, it's about as simple as that.
There are some users who have posted issues here:
Good luck, and if you have any problems, please don't hesitate to post here or contact Solarwinds support.
Thanks!
