Community
Command Central
MVP Program
Monthly Mission
Blogs
Groups
Events
Media Vault
SolarWinds Academy
Products
Observability
Application Management
IT Security
IT Service Management
System Management
Database Management
Goal Oriented AI
Content Exchange
SolarWinds Platform
Server & Application Monitor
Database Performance Analyzer
Server Configuration Monitor
Network Performance Monitor
Network Configuration Manager
SQL Sentry
Web Help Desk
Free Tools & Trials
Store
Home
Products
Lost tree view --[[help]]--
casnik
for some odd reason, i do not know, I have lost the tree view in Network Performance Monitor. Can anyone tell me how to get it back, and what I did to lose it.
Find more posts tagged with
Accepted answers
All comments
Grabowski
I had the same thing happen to me once in a previous version. I believe that I ran setup wizard again, which solved it.
Lars Grabowski
Global Infrastructure
Chr. Hansen A/S
Currently using:
Cirrus Version 2.1 DL-500 Feb. 2006 (8.1.42)
Orion Application Monitor 7.8.94
Orion Web Engine Version 7.8.133
Orion NPM SLX 7.8.5 March 2006
Alert Manager 8.1.15
Janis1
There is a Knowledge Base entry that has step by step instructions for resolving the node tree issue. The KB entry is
support.solarwinds.net/.../ProblemDetail.cfm
Janis
casnik
that brought my tree view back but no scroll bar, node details box and all the interface links do not work..
anything else I can try?
btw, ALL i can see is the tree view, no links from the tree view work either.
casnik
----update----
now I also cannot go to any OTHER view, I basically just lost all administrative functions with the user interface.
mjsenno
I'm having a problem too. Any update
pwaller
You can change it in the registry
Start\Run\regedit
For Performance Monitor:
[HKEY_CURRENT_USER\Software\VB and VBA Program Settings\Orion Network Performance Monitor\NodeList]
Set "Visible"="True"
and "Width"="5550"
For MapMaker:
[HKEY_LOCAL_MACHINE\SOFTWARE\SolarWinds.Net\MapMaker\Settings]
Set "Node Tree:Show Addresses"="True"
and "Node Tree:Width"="5550"
Hope this helps, Paul
Quick Links
All Categories
Recent Posts
Activity
Unanswered
Groups
Help
Best Of
