Community
Command Central
MVP Program
Monthly Mission
Blogs
Groups
Events
Media Vault
SolarWinds Academy
Products
Goal Oriented AI
Observability
Application Management
IT Security
IT Service Management
System Management
Database Management
Content Exchange
SolarWinds Platform
Server & Application Monitor
Database Performance Analyzer
Server Configuration Monitor
Network Performance Monitor
Network Configuration Manager
SQL Sentry
Web Help Desk
Free Tools & Trials
Store
Home
Products
Solarwinds and NAT
virgilv
Can anyone address this question for me?
Many of the network mgmt tools (OpenView, CA Unicenter, etc.) do not work well in a NAT environment; i.e. if you begin discovery of nat'ed addresses, followed by snmp polling, you run into issues because the software now wants to use the IP addresses that were discovered in the SNMP poll.
I need an application that you can configure to keep the nat'ed addresses as a polling reference, but still use snmp to do your monitoring.
Can Solarwinds do this?
Vik Evans
Network Security Engineer
Find more posts tagged with
Accepted answers
All comments
iunderwo
I think I understand the question you're asking.
SW can poll any device based on an arbitary IP address. If that address is a public IP like 223.4.4.1 which is NAT'd to 10.1.1.1 internally, SW will still go after an poll the public IP. It doesn't change the address it's going to poll unless you tell it otherwise.
Polling and SNMP monitoring use the same address in all instances. If you need to keep a separate record of what the internal address is, you can use a custom property.
// Ian Underwood - Service Management
// Level 3 Communications
Quick Links
All Categories
Recent Posts
Activity
Unanswered
Groups
Help
Best Of
