i would like to see a 64 bit version of the solarwinds products, This would allow the product to access and use more addressable memory within
the Servers i install the products on.
As all modern OS's run 64-bit, and very few are still running 32-bit, it doesn't make since not to make the SolarWinds product line 64-bit to be able to take full advantage of the capabilities available on 64-bit OS's
There is very little 32bit left in the Orion Core. I spoke with one of the developers recently and he mentioned they are almost done with the removal of old VB6 code. They are moving to completely .net 64 bit. He also mentioned that the job engine and module engines along with many other needed processes are already running in 64bit. Just an FYI. I will still vote on this, but this is definitely all continually in progress according to SW dev.
How about a Linux based Appliance that allows you to add on features with unlock codes. 64 bit of course.
It's never gonna happen, but I liked your comment anyway. A guy can dream...
The only tangible benefit to 64bit is that a single process can address more than 2GB of ram. It doesn't improve performance in any way. Not unless you have a process that's memory constrained. As you can see below, no single process comes anywhere close to consuming that amount of memory.
My business-layer aka moduleengine died regularly because it hits the 2GB limit, at least until I got YABD last week.
/RjL
YABD: Yet-Another-Buddy-Drop
That sounds like a memory leak issue. A 64bit Module Engine process would simply have let the process leak further. While I don't think anyone is opposed to the idea of a 64bit version of Orion. In fact the Job Engine is already 64bit as anyone with SAM can see by editing any assigned application, expanding the "Advanced" section, and selecting x64 job processing. This tells the job to use the 64bit Job Engine instead of the 32bit Job Engine. This option exists and defaults to x86 (32bit) because not all jobs can be executed properly in a 64bit processes. E.G. Calling 32bit PowerShell cmdlets is a good example, or opening an ODBC connection that relies on a 32bit ODBC driver.
Which I could vote more than once....and our deployment isn't completed.
Try this tip!
Tip: How to Improve Orion Performance by Splitting the Module Engine to Separate Processes
So Just theorizing here, but have ran into countless issues that seem to come back to the lack of 64-bit processing in Solarwinds/Orion. The SDK API for example does not allow the transfer of a 4-byte AS that greater than 2,147,483,647. And results in either a negative number, or if you perform math against a string representation, the conversion to an integer results in an elusive error: The conversion of the nvarchar value '4227927296' overflowed an int column.
Others have argued and requested 64-bit under the suspicion that running in 32-bit translated mode (using WOW64) is causing performance issues. Reasons stated include
In multiple forum posts, engineering defends their reason for not porting to 64-bit as not required and complicated. Under the following reasons:
This is not a knock on the Solarwinds/Orion Team. The company I work for has been loyal customers since 2005. I personally have used the product since 2000ish.. maybe as early as the late 90s. They product they have created and maintain for the cost of ownership is extremely powerful. However, I like many others would like to see resources dedicated to the future instead of arguing to stay in the past. I completely understand that are large portions of the system that complicate the ability to transition to 64-bit. But in the end, I like many others think the product will scale and perform much better.
But I do think honesty from the Solarwinds engineers (or education where misunderstanding the myth of 64-bit performance) will go a long way towards the continued support of the product by its userbase. There needs to be the announcement of an initiative to get to 64-bit and there needs to be adequate emphasis and communication to the userbase on how and why it will take whatever time it takes to get there.
Thanks!
This would be a good thing...
It would also be very beneficial to be able to use for e.g. 64bit Oracle ODP drivers to monitor Oracle RDBMS. We have systems that cannot use 32bit drivers as the appstack vendors prohibit modifying their environment and they only support 64bit.
