Happy Valentine's Day to you all! That video was a classic.
I now feel like eating chocolates mmmmmmm.
IPv6 =
ROFLMAO !!
Thanks DanielleH !
Thanks! Happy Valentines to all
This was great. Thanks! Happy Valentines Day!
what's wrong with IPv6?
this should be in the store...just sayin'
Made me laugh! Hahappy Valentines Day!!!!
I needed that humor on a Monday despite it being three days past Valentines Day.
I always hated those bit of honey on halloween... really hard and felt like it was going to pull your teeth out! The Mary Jane's weren't much better either!
thanks, needed that on a Monday!
Well done!....
\m/
