Hi
I need create a custom report
how to edit a report
To create a custom report, you'll use the Report Writer application on your Orion server. You can't modify or create reports on the web console. If you're using version 9.1, you'll find the Report Writer on your server under SolarWinds Orion | Alerting, Reporting, and Mapping | Report Writer.
