I have already voted. Ok. Anyway the biggest challenge is visibility.
I have voted, but none of the option here are my issues. The biggest issue is time, manpower, and cost to maintain a system. SolarWinds is not hard, but when you add in other tools like Forescout, Acrsight, ACAS, ISE along with the Networking piece it takes a village to manage your complete Enterprise Monitoring Suite. Reducing Technical Debt is a solution but that also takes time.
I have voted also but my Day 5 question still looks like I did not answer
I voted as well, question on mission still shows as unanswered. I recall when first starting in managing alerting was just the sheer number of alerts that needed to be squelched down to make them actionable. Something that needs to be done early and often and is in the alerting 101 book, but still something that many struggle with.
I agree with Eric.
The ISE alone is a lot to take in. I've got it all running now but it wasn't trivial getting it working with all the certificates and PKI chain back to the various authorities.
Bill
why didn't i get any points when i voted???
Interesting poll
Agreed
I have voted but the day 5 option is not marked as completed or giving out the points.
probably misses his old glasses.
Turn around Reverend, you're preaching to the choir. The complexity of SolarWinds and an inexperienced admin at the helm is a recipe for an ordeal. Add an older, faltering SW environment that was maintained at a best effort rate, then you have my current position. I can thankfully say that my manager and my colleagues have been amazing at helping to make sense of the mess.
Same. voted but no points
voted, but didn't get any points, also it's not showing completed either.
Points have not been added
Vote still isn't being counted on Mission CTRL main board
Voted last week, still no green check mark...
I have the same issue, voted, But didn't clear the mission item or award points.
I have voted and unfortunately haven't received the check mark or any points either.
volyt
Unpredictable outage and remediation costs - This is huge cost and blind spot.
The costs of manpower required to maintain systems for monitoring is a significant issue.
I'm sorry voting polling has been disabled by hackers.
Tried to vote. Vote closed before monthly mission was over.
Day 5 of monthly mission did not mark complete or give out votes
Alright!
