I saw in the patch 4 for 9.1 that the ability for non admin to change their own password. I however patched my Orion from SP3 to SP5 and do not see the feature. Does anyone know how I can get this feature enabled?
Todd, try the following in the Orion NPM web console:
Admin -> Customize Menu Bars -> Find the menu bar assigned to the user(s) -> Edit -> Click on the green "+" -> Check next to "Reset Password" -> Submit
This will add the reset password option to the menu bar.
Thanks Samuel that did the trick!
