Even with all the genetic engineering it's hard to not go with the classic robot enhanced cop story. Six years changed a lot but they did really good with RoboCop.
To ease your mind, the answer is 100%, without a doubt, yes.
Technically we're closer to the RoboCop reality than the Jurassic Park reality currently...
Hold on to your butts!
Nedry FTW!
Both movies about bringing the dead back to life. In both cases, the reanimated makes live things dead. I think I want the one that eats baby food, not babies for food (if they had the opportunity).
Some days I can't decide if modern corporations are more OmniCorp (RoboCop) or more Initech (Office Space).
Other days, I choose to not dwell on it.
For Robocop, the magic word was "You're fired!"
AH AH AH... you didn't say the magic word. LOL.
