Thanks for putting these out there!
We work with some groups in India and they were having some issues with some data transmissions. They were saying it was something on our end then I pulled up NetPath and put in their site and let NetPath do its work and within 30 mins you could see that when the data hit routers/internet equipment in India is where the issues started. Needless to say I love NetPath!!!
\m/
