Riverbed Steelhead hardware monitoring
We are currently monitoring some of our Riverbed appliances. I don't know if this will give you everything you are wanting but by default it gives us the CPU Status and the System Health.
At my previous company,I was monitoring dozens of Steelheads, and I had set up an advanced alert for them to alert on hardware health, using the Riverbed MIBs. You should be able to do something with this already.
I am pulling this data via UNdp, but having it all built in is MUCH more efficient. Reporting is better, alerting easier, etc. When there are many others that need to understand the internals of Orion in your/my company, the simpler the better.
Also, that is a big selling point of Orion, Simplicity. It is easy to use and easy to navigate. The more things are standard the more SW follows this ideal.
Thanks for clarifying. Sorry I misunderstood the request.
a vote for simplicity bump
#bumpsquad
would be good, if hardware support is available default.. currently even we are utilizing only trap based and UnDP...
