I think this feature request sits in a grey area somewhere between NPM and Virtualization Manager but it nice to see solarwinds be able to monitor or support Vmware NSX down the track
thanks
We're certainly tracking NSX adoption for support. Curious - what sort of new problems are you encountering with NSX?
Alerting of config changes is not native to NSX and is a big hole in being able to audit changes.
It would also be nice to get some performance metrics from it, so customers can see their usage stats. Also VPN tunnel monitoring would be good as well.
bump
Bump for 2019! Any plans?
We use VMware NSX, are there plans to support this product?
Bump
This would be big for us as well. We've ran into communication problems in NSX in the past that were not easily identified.
Bump up for NSX-T. I believe I saw this mentioned on the roadmap?
Bump, any update when VMWare SDN (NSX) is on roadmap to be monitored either in NPM or VMAN.
NSX adoption is going to grow due to: VMware Cloud Foundation growing in popularity (NSX is bundled in it), growth of VMware-on-cloud solutions (AWS, Azure, GCP) which all use NSX, and overall NSX-T maturity level.
The only case where this doesn't happen is if VMware adoption in general goes down due to on-prem infra dying (I suspect Solarwinds will have other problems if that happens!)
Is Solarwinds planning on adding it? Should be a part of the Virtualization plugin, imho.
Jumping if it hasn't been looked at...
Any update on this thread from SolarWinds?
Dear Solarwinds,it would be great to get an answer how you think about this feature.
