I think the Matrix vs Office Space button is broken. It keeps taking me to this page which I already voted on.
Same for me.
I was able to find it. If you click on Brackets at the top it takes you to a different page and you should see the bracket.
[Semifinals] Office Space vs. The Matrix
Yep - make that 2 Matrix-related screw ups by yours truly.
I honestly can't decide on this one. Two of my all-time favorite movies. This might come down to comparing the technology and which did it better.
This is a really tough one... great match-up. Very interested to see how this one plays out.
It will probably be JP, but personally, I am pulling for WarGames.
Tough choice, going with the classic. Wargames.
Do you want to play a game! This is easy.
Real hard choice. I have voted for both of these two candidates each time. I have to go with WarGames though.
Shame that Tron didn't make it to the end, it's THE on-theme title out of them all! Still, WarGames will get my vote for this round.
It's a UNIX system, I KNOW THIS!
