\m/
@KMSigma.SWI Has the glitch been fixed where if you select a single server in the top box, click one of the buttons at the bottom then an option on the right it will default to the whole container even know only a single server is still highlighted in the top box? If you are not very careful it is easy to apply what you are doing to the whole container, and that might be the all computers group.....
