Add Templates for Managing HP Chassis
Does anyone have this template?
Do you mean a configuration template?
I would like to be able to manage HP Virtual Connect configs from NCM.
On Fri, Jan 3, 2014 at 10:02 AM, bbtrev <
Those and the onboard administrators are just CLI and text config so it should be possible. I plan to move a C7000 and flex10 into the lab sometime in Q2-3 to test with.
stevenstadel,
Check if these work for you?
HP VirtualConnect Flex10-1.3.6.1.4.1.11.5.7.5.1.ConfigMgmt-Commands
HP Onboard Administrator-1.3.6.1.4.1.11.5.7.1.2.ConfigMgmt-Commands
Are these templates still the best way to get data form an HP C7000 blade chassis? I would like to see things like fan speed; power consumption etc. How are these template files used?
Many thanks
Hardware health is now supported natively for the onboard administrator IP.
Add one and see if you like that- otherwise you can still use custom poller OID's
