Are your Windows Security Logs overflowing? Have you noticed more noise on your logs than normal? Changing your Audit Security Settings can cause a flood of data that you may not have realized is now invading your logs.
Having to muddle through extraneous information is cumbersome and time consuming, especially since auditors require that logs be reviewed on a daily basis for any suspicious events or alerts. You want to streamline the data to be analyzed and changing your Audit Security Settings may help filter out the noise. For more information on Windows Auditing and the extra noise it creates, check out our Not All Windows Auditing is Created Equal blog article.
For information regarding log management, see SolarWinds Log & Event Manager.
