The Title does not match the video content. It talks about AWS and Azure, no mention of Vulnerability and Risk management.
Amazing!
@ChrystalT are you (or have you already) actually going to do an update on "Vulnerability and Risk Dashboard" - this is a feature we used previously in my org and with some recent updates we seem to have lost some functionality and visibility (indeed we had to do some SWQL magic to restore our previous analysis of the known CVE's)I'd like to see what is available over and above the actual dashboard itself, how do we view all CVE's easily, how do we review/assess/mitigate/document each one against our estate and our estate against each one... etc.
Hi, @Daran , I certainly will look at doing an update. This video was only meant as a product update and not a how-to. For your question, you can get to the full list of CVEs in a couple of ways. From the Vulnerability and Risk Dashboard, clicking the widget titles for Vulnerability Counts will take you there. Selecting one of the severities listed will take you to the list with an automatically selected filter for that severity level. OR you can get there from the breadcrumb trail of any individual CVE. Pictures for reference:
Hope this helps!
thanks @ChrystalT but the video doesn't even mention it - it's about AWS/AZure.
I am aware that clicking on a wdget title takes you to the more detailed data but in previous versions we were able to review the CVE list, add comments, manage/accept/mitigate reasons etc. in bulk for devices/models but this seems to have gone (or perhaps I am mis-remembering
Anyway, a session on this feature and any insights into further development would be great!
Thank you! I didn't notice it was the wrong video. I've corrected that. Thank you for the suggestion for an updated video as well.
