Where ***? No see ***.
No disassemble.... it was just a much more fun movie.
Short Circuit. Ex Machina hits a little too close to home. But that's a story for another blog. ;-)
The best thing about this bracket battle is its showing me about a dozen new movies to watch!! Add ExMachina to the list (but I have to go with the sentimental one here, Short Circuit was a great flick).
Would you like to be a Pepper, too?
Ex Machina - beautifully well done.
NUMBER 5, IS ALIVE!
Johnny 5 will not be alive after this round ... see what I did there?
