Currently Patch Manager provides the capability for email notifications on task completion.
What do you think about having an email notification on task Startup?
cannot go wrong with more communication options
Personally I would prefer only the post-job email but with more information: start time, end time, details about the task completion, etc...
Details about task completion can be obtained by enabling a "Task Results Export" and then attaching that to the email notification.
I would love to have this feature. I would like to know that my scheduled tasks have kicked off as scheduled, since I've had problems with them getting disabled unintentionally.
Hi Lawrence,
I know you can export the task result and I do so for several tasks. My comments was only for the email body that instead of just having a phrase like "Task X has completed on Application Server (Server Y)", could have a summary info with start/end time, etc.
Let me give you an example of what I mean. The task for WSUS Server Cleanup has this information on details after task completion:
Perform WSUS Server CleanupObject: IGFCSS-WSUSStatus: SuccessDetails: Disk Space Freed: 27957418 Expired Updates Declined: 0 Obsolete Computers Deleted: 0 Obsolete Updates Deleted: 0 Superceded Updates Deleted: 0 Updates Compressed: 13 Configure Computer Deletion Threshold: False Computer Deletion Threshold (in days): 30
It would be really nice if that text was on the body of the email message.... Just a though!
Gotcha!
This is a great subject ,I am still new to computer programming and group projects, but I am learning. let me explain back in 2010I had strokes that took me away from my career, after recovery I found that I couldn't do what I did before anymore.So I decided to go back to school, and learn more about the technical world.SO far I have done well in my studies.enough avout me, I will just keep an eye on the post and learn from there.
ThankYou
Pete
Change control is a part of life in IT. Alerting to start of task would be awesome and goes hand-in-hand with task completion.
Would like to see this.
