Missing Custom Properties from User Interfaces
If you are
unable to select or see your custom properties while using other Orion tools,
for example the Account Limitation Builder and the Web Console, a workaround is
available. At this time, complete the following workaround to repopulate the
missing information:
1.
Start
the Custom Property Editor from the Start menu.
2.
Click
Add Custom Property.
3.
Click
Build a Custom Property from scratch.
4.
Create
a placeholder custom property. Ensure the default values do not interfere with
any previously created properties. If they do, add a random string to the Property
Name field.
5.
Click
OK.
6.
Ensure
your previously defined custom properties are now available for selection in
other tools.
7.
Delete
the placeholder property.
This issue is
known and will be addressed in a future release.
