alright
definitely yes
not critical, but Azure can get cluttered quickly when there ane many engineers building things.... so I think a daily/weekly report/widget that states these are the new items discovered or missing....
It might be helpful to specify this as "within cloud-based IaaS (Infrastructure as a Service) environments." There probably aren't many cases (if any) where a SaaS or PaaS customer would have network elements to monitor, other than the connection to the service itself.
It would really depend, most of our cloud implementations are 3rd party.
