\m/
A combination, depending on the severity and importance of the alert
Dashboard during working hoursEmail after office hours
IT is email with a mix of the all of the above. I truly want to look more at webhooks with something like slack or teams. Let the support personnel subscribe to the channels to get the relevant alerts to them and they can chat inside the channel then. Honestly, it is also a last ditch effort to stop teammates from creating an email rule to send to alerts to that special place...
I only want critical alerts in an email. Other alerts can just be on a dashboard.
Via SNMP Traps or it would be even better via MQTT
I lock Text, Email, and Phone Push Lock Screen notifications...
Dashboards and emails for me! I'm not connected to the outside world so no pages or outside emails.
All of the above!
Ditto
Email for most SMS for critical
My customer requires alert information to be delivered in "all of the above", depending on the alert information provided. Primarily Dashboard alerts.
All of the above.
I don't...
