Dear Team,
It has been an issue for a while now - the filtration of all widgets when using View Limitations needs some fixing.
When I am using NPM, SAM, WPM and other modules, View Limitations (on the view as well as account level) is not working as expected.
If I limit the view using Network Devices (most common), I can still see alerts for Netpath, Network Discovery, WPM, SRM and other modules (even if a network device has nothing to do with web transactions, arrays etc).
In the Event widgets, I see audit and other events completely not related to my device limitation. I can also see Groups, but they are empty. This is very confusing for my customers and I need to do many workarounds, such as limitations per widget, which can be time consuming and not all widgets support it.
You can see an example below.
Kind regards,
Marcin.
